awdgraybird
- Sep 2, 2011
- 14
ok so i am trying to help my buddy fix a boat he picked up a couple years ago. it has a 1969 johnson 115 v4 hydro-electric shift on it i have read all i can find on them. when i started with it it had only forward found it had bad seals and had water in the lower unit so i pulled it put new seals in it and a new water pump and filled with omc premium blend. it now has forward and neutral but no reverse so i pulled it again and turned it over with a drill and put power to the green wire for nuetral and could not even get that so what i am wondering is first what i am doing wrong that it is not shifting by putting power to it. what is the likley problem with it and were i can find a factory service manual for the thing thanx
