1969 Evinrude lark fuel mix question
Kimytrav
The cover of this motor says 1Qt. SAE30 for 5 gal. I just bought it from my neighbor who has been putting 8 OZ. 2 cycle per 5 Gal. for a couple of years. I took it out on my maiden voyage mixing as he has and it smoked like George Burns! My estimated full throttle speed was about 1/2 MPH. before it died and I had to row it in. any suggestions? tHANK YOU!!!
Joe Reeves
Re: 1969 Evinrude lark fuel mix question
Fuel/oil mixture is 50/1 (1pt of 50/1 oil to 6gal gas). Fuel octane rating of 87 is fine.<br /><br />(Compression & Spark Test)<br />(J. Reeves)<br /> <br />1st - Regardless of what problem one might encounter, always start with the basic troubleshooting procedure. Check the compression which should be in the range of 100+ psi (somewhat less on the smaller hp engines) and even on all cylinders.<br /> <br />2nd - With the spark plugs removed, rig up some type of spark tester whereas you can set a gap to be jumped. On magneto ignition systems (yours), set the gap to 1/4". The spark should jump the gap with a strong blue lightning like flame..... a real strong blue snap!<br /> <br />If the above checks out as it should, and the engine dies out when throttle is applied or won't idle, it is usually due to the carburetor being fouled, in which case the cure would be to remove, clean, and rebuild it.<br /><br />(Carburetor Adjustments - Two Adjustable N/Vs) <br />(J. Reeves)<br /><br />Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns. <br /><br />Setting the high and low needle valves properly:<br /><br />NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle va /lve adjustment.<br /><br />(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, wating for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting. <br /><br />(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting. <br /><br />When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
JB
Give us a model number, Kim.<br /><br />I need to confirm that it is really a '69 and really a Lark.<br /><br />Otherwise, what Joe said.<br /><br />Good luck. :)
Kimytrav
It turns out the motor is actually a 1956 30 hp. Model 25526-02793. I've ordered the service manual, when it gets here I'm going to rebuild the carb. The compression is good, The spark is good (pretty black plugs though) I found the throttle stuck closed in the carb and fixed that and things are sounding better. Just need to rebuild...It sat for 2 years also. Thanks again!!!
Paul Moir
Don't forget/neglect the water pump!<br />24:1 87 octane gas and TC-W3 outboard oil for that one. ;)
