1969 Evenrude Sportsman 155 key switch
wbnj
Key switch seems to be shorting. everything will work nin off position, the must turn switch to run for lights , tilt ect to work. switch marked KF 81 local parts store cannot help. anyone got an idea?
Thanks
HT32BSX115
Re: 1969 Evenrude Sportsman 155 key switch
Thanks
Howdy, and Welcome aboard.....
You're in the wrong forum. This is for I/O's and inboards.....
You probably want Non-Repair Outboard Discussions
Regards,
Rick
Howard Sterndrive
it's a boat. i/o
you can still get that ignition switch at any Evinrude dealer
#39 0378238 IGNITION SWITCH & KEY ASSEMBLY 1 $47.26 Available
or #6 if you have this setup
you can look up all the parts at shop.evinrude.com
and here's a schematic: http://hhscott.com/evinrude/images/wiring/68_v6_ALL_WIRE.jpg
