1969 Chrysler 7072 Woes
tlowery04
I was wondering if anyone on this forum knew where I could get the part number for the cd black box for my motor. I've just purchased one online and I beleive it is the wrong one, having a red white and black wire then a white/black, grey and black wire from the side.
Also I was reading here, that the MSD-5520 may be an adequate substitute. If the box I have is from a newer model can it be used on this motor?
I found a boat yard where the guy has a mountain of boat motor, I'm sure he has a Chrysler somewhere in there but he said he wanted a set of part numbers to look for which I dont have considering the part was missing from my boat when i bought it.
thanks in advance!
Nordin
Re: 1969 Chrysler 7072 Woes
Post some pics. Easier to help you then.
jerryjerry05
Maybe Frank will see this,He deals in older stuff.
Like Nordin suggests Pics and a few of them.
Salvage yards:
sea-way.com
outboard-parts.com
laingsoutboards.com
tcoutboard.com
fairwindsmarina.com
salvagemarine.com
marinepartsoutlet.com
Superior Marine (800-338-9281)
trixieslanding.com Trixie’s Landing, Bayville, NJ 732-269-5838
americanoutboard.com
piratemarinesalvage.com/
Don's marine Salvage, 5601 126th Avenue North Clearwater, FL 33760 - (727) 576-8577
timsoutboard.com
http://www.shipwreckusedparts.com/aboutus.html
http://www.mmsalvage.com/
Valley sales Prudenville,Michigan. On net get phone # and call he's slow on the e-mails
Frank Acampora
Gee-- That is a knotty one. The red wire is definitely power to the capacitors while the white is tachometer signal. Now, black is almost always ground but it COULD be in this case a power to the internal electronics. On the side, white/black is signal from the points while grey is to the positive on the coil. Black is a ground.
If you are willing to take a chance, attach the box with the black from the red, white, and black group to ground. If no spark, then try attaching black to the BLUE from the ignition switch. --no guarantees here and it is a crapshoot on your part. It may damage the CD unit.
