1969 6hp carb removal
liz873
Need to remove carb on 1969 6hp johnson. Appears I have to remove pull starter to get at 2nd nut? (bummer) . Is this correct ? Any tricks on removal of pull starter in regards to spring tension so I'm not left with a mess. thanks
ONERCBOATER
Re: 1969 6hp carb removal
yes... tape strings zip ties... all been used to follow his directions.
Sean
Tim Frank
This is why it is always suggested that your first step should be to buy a Manual. (I got my 6HP OEM manual for $20- on eBay, delivered. I'd pay $100- now, in a heartbeat).
There is a lot of trouble waiting for you if you mess with that starter without knowing what you are doing...and the manual will help you avoid most if not all of it.
liz873
Yhanks to all. Found all you do is remove top screws of starter which allows you to push it aside without disturbing anything to get at nut. All you need is a little wiggling to get starter rewind seated again. Manual is much needed.
