The Starcraft Enterprise
Thread starter- Joined
- Oct 19, 2011
- 65
Engine does not want to start when it's a little hot. I put new gas in it, new fuel pump and there are farely new spark plugs. I also cleaned the carberator. When it was cold it ran fine and ran it for about 5 minutes and cut the engine. 10 minutes later it ran fine again. On the third start up I couldnt start it. When finally got back to shore, I noticed that the carberator pin was really loose and it fell out. Could this be the problem? Electrical problem? The water pump does work but its more of heavy mist and not steady stream. Water pump?
