1969 40 Johnson Supersea Horse
Hey,
I have some issues. I bought this boat and motor late last season and only used it 5-6 times. I even had it serviced right after I bought it. The motor ran great until the last boat outing. I would have the throttle floored and the motor would just lug and go very slow. After that I stored the thing for the winter leaving half tank of gas in the tank.
This year, I topped the tank off with newer gas and changed the spark plugs and its still giving me crazy symtoms like last year. Any thoughts? dirty carb?
Daviet
Re: 1969 40 Johnson Supersea Horse
Do a couple of simple tests first, check the compression and spark to see if you have a dead cylinder.
If those check out, might be time to overhaul the carb.
Daviet
Depends, if you no compression, you need to pull the cylinder head and see what's wrong. Maybe a defective head gasket. If you have no spark you will have to pull the flywheel and check out the ignition system.
