1969 40 HP Johnson - Engine Siezed after winter storage
Pulled my boat out of storage after winter. I tried to give it a test run today and now I cant pull the starter chord. The engine is seized up. Does anybody have a solution for this? Is the engine toasted?
Can you reach the flywheel to see if it turns?----------Is throttle advanced too far ?
Can you reach under the starter and turn the flywheel?----Can you pull on the starter if you back off the throttle ?----Questions should be answered !
