1969 25 hp venture troubles
randomguy
Hello everyone, I am looking for some help and advice. Recently my 1969 25 hp evinrude has had some trouble.
First, it had signs of a spun prop, so I marked the prop, and it was spun. So I replaced it. Next time out on the water, seemed to run fine, no spinning. So I went fishing for a bit. Boat had been sitting in the water for a couples hours. When I went to leave, I started heading back up the river, and noticed my engine would start to... "hiccup". That's the best way I can put it. I had it at WOT, and it would just keep having a little sputter or "hiccup", but would then keep going.
Just emptied my lower unit oil, and the oil was completely milky white, and pasty.
So, could this have caused it? Do i just need to replace some seals? Could there be more to it ?
Thanks for any help you can provide.
lindy46
Milky white means water getting in to the gearcase. First, are there crush washers on the fill and drain screws? If they're missing, that would be the most common place for water intrusion. There are also seals around the prop shaft. drive shaft, shift rod opening, skeg and pivot pin. A seal kit would have all the seals. The "hiccup" is most likely an electrical problem - one cylinder periodically cutting in and out. Could be as simple as dirty points or possibly a failing coil.
F_R
Honorary Supreme Mariner
Sounds to me like the classic description of a worn clutch dog. Most people describe it as feeling like they hit something. Begins at WOT, gets progressively worse and if you let it go long enough won't stay in gear at all. It's to your advantage to fix it now. Every time it jumps, it causes more damage. Besides you need to get in there for the seal job anyway.
randomguy
Thanks for the help lindy and f_r. I was thinking it may be the clutch dogs after doing some reading on here, and also noticing it only when it's in gear. Are replacing the seals and swapping the forward and reverse clutch dogs, or replacing them very hard tasks? Or could a guy with decent mechanical skills like myself get them accomplished?
AlTn
youtube..johnson/evinrude 18/20 hp. lower unit disassembly...that's what's involved..
