1968 mercury 3.9 hp cannot find telltale peeho;le
appleo
1968 mercury 3.9 hp red band cannot find telltale peeho;le
MY fatheers engine started right up cannot find hose or pee hole where water should be coming out...
just installed a new impeller
SN 244xxxx shows it a 1968 red band all the videos on youtube show water stream ..... but no view under the cowl
any help or photo apprecaited much thanks
Chinewalker
I believe there's an outlet hold directly under the rear of the belly pan on those little singles.
appleo
There is a hole in the bottom cowl no hose or connection to water jacket i can find
theres an exhaust hole dead center rear but all the videos i saw that is exhaust only
the peehole is on the tiller side
there is flush plug on opoosite side.... i can see where it is ported to the the jacket
however when i flush it all runs out the water intake in the Anti ventilation plate
