1968 Glassmaster Runabout
fstorm08
Picked this up for $200 a week or so back.
Any suggestions on how to fix the windshield?
Thermoform a new one?
Cadwelder
Re: 1968 Glassmaster Runabout
Forming is about the only option....windshield are the hardest part of boat restores to find.
fstorm08
Well got the bulk of the rotted floor out tonight.
Seems kind of odd that the center stringer does not tie into the bilge box :confused:
No foam either. I guess it was not required in 1968 :confused:
fstorm08
Any suggestion on getting a seized steering cable out of the tilt tube :confused::confused:
fstorm08
For the hell of it, I drilled 3 test test holes in the transom.
Once I drilled each hole, water started coming out :)
:facepalm:
fstorm08
Got the stand built and motor off today:
Then got the rub rail off and got the rear part of the cap/splashwell off in prep for removing the rotten transom:
fstorm08
I had a helper last night helping get the rest of the rotted transom out :)
Cadwelder
Looks like you're ready for some grinding.
fstorm08
Yup :)
I started a little last night but started getting eaten alive by the mosquitoes :(
The 24 grit disk on the 4.5" angle grinder goes through that stuff pretty quick :eek: so I will need to be mindful when I continue grinding.
Cadwelder
Yes it does, you only need to grind enough to get down to good fiberglass and make sure all the old wood is gone. Try to keep it as flat as you can.
fstorm08
Thank you for the tip. I will make sure I do that.
wsu_liston
When you removed the rear part of the cap, was their a factory seam or did you have to cut it? I have a 67 Glassmaster and am worried that I too need to do transom repairs.
fstorm08
First I removed the rubrail and transom splashwell cap.
I then made sure there were no wires or anything like that, then cut it with a sawzall using a 24teeth per inch bi-metal blade.
It did take a bit after that as the seem between the cap and the hull has a few layers of glass to cut through with a right angle air cutter. Also a nail-bar and hammer helped with the final separation of the back part of the cap and hull after the cuts were made.
I figure I will join the back part of the cap to the rest with a layer of CSM and a layer or two of 1708 on the inside and a few layers of CSM on the top when it's is time to put it back together.
fstorm08
Did a little more cutting and grinding in the bow today:
before:
after:
Also took a bunch of pics and measurements before I start cutting/ pulling out the stringers.
fstorm08
Well got the boat covered and driveway picked up in prep for Irene:
However before that, I got the slab of Swiss cheese that is the splashwell, ground down as I figure I will just fill in all the cable holes with layers of CSM and 1708 and re-drill in the right place/s when the time comes:
Boy those 24 grit disks on the grinder sure move some product.... quickly. I didn't keep it moving fast enough in the corner:
That's it for now. Going to get back to scratching my forearms where the coveralls did not seal ;)
fstorm08
I was thinking a bit ahead today and was wondering what you all thought of mounting a 12 gal gas tank in the bow (like what Micks110 did on his AT restore)?
I will probably have 2 batteries in the stern and was thinking that having the 12 gal in the bow might help balance the weight a bit instead of 2 6 gal portables in the stern with the batteries :confused:
I'm open to any feedback.
Thank you
