1968 evinrude fisherman 6hp running issue
Ktryd
I have a 1968 evinrude fisherman 6hp that I rebuilt from seized. I got this motor cheap and had to pull it apart and re hone/ score the cylinders. I used a ball one to do this and removed the rust from the bottom. I cleaned the Pistons and checked the rings. Replaced all the gaskets and checked all the points. I just ordered a rebuild kit for the carburetor. Had it running in the tank and idles good lags when giving throttle. Both cylinders read 70 psi. The issue is when I put it in gear it has low RPMs and goes slow. It pushes forward but only at full throttle. Fuel is 50:1 with sea foam in fuel. Using 89. Any suggestions or thoughts on how to have more power ?
oldboat1
sounds like it's running rich. don't know if seafoam has that effect, but try adjusting/readjusting the idle speed needle. Start 1 1/2 turns open from seated. With motor running and warmed up, try for leanest setting where engine idles smoothly and can shift gears without issues.
Lean is clockwise.
Ktryd
That's how I have the idle set 1.5 out. Idle isn't the issue its when it is in gear has loss of power.
oldboat1
1.5 is an initial idle setting. best running likely different than that (though not necessarily). Try setting as lean as the motor will let you (idles smoothly, and shifts without stalling). If you've got that dialed in, but have issue at higher rpms, that is likely a partially plugged high speed jet (which you cannot adjust). You might take the cover bolt off (down at bottom front of carb), and spray carb cleaner in the opening. May clear the jet. If that fails, likely need to disassemble carb and thoroughly clean -- soak, small wire in all passages, blown out with carb cleaner. Kit with new gaskets, float jet and needle. On track, I think, with a kit on order.
Tim Frank
Do a drop test to make sure that both cylinders are firing.
If not, check spark with a tester. Spark should jump ~ 1/4" gap.
Free tests while you wait for your carb kit.
geoffwga1
Ditto what Tim said.This screams IGNITION to me.How old are the coils? If original they are probably shot and unreliable.I would replace the points,clean and polish them before assembly,(even new ones as they have some preservative goo on them.If you haven't replaced the plug wires cut 1/4 off of the coil end make sure the little screw thingy in the coil screws right in.Cut 1/4 inch off the plug end and fold the wires back along the wire before fitting the spring contact in the boot. Make sure the green wire to the points is not going to rub on anything.Torque flywheel to 40-45lbs( might just check on that,don't have my book handy)and away you go.you should now have sparks that will jump at least a1/4 inch in open air.Keep us posted.
Ktryd
Worked late have a rebuild on order will pick up a spark tester inline tomorrow. Points and plugs are newer
Ktryd
So got time to rebuild the carb and set the low idle. Still lags when giving throttle. Had the points cleaned and reset to .020 turns over with one pull but when shifted in gear it has no power still .
ondarvr
Did you check and see if it's running on both cylinders?
Ktryd
It is running on both but I need to set the points. Was looking at Easy ways to set the points. Besides a feeler gauge
Tim Frank
So, you were going to get a spark tester....still no report on that. Absolutely critical test.
Let us know when you have actually read and performed the tests that have been suggested. Then we might be able to help.
S.A. Baker
A feeler gauge IS how you set points! You are setting max gap on the high point of the cam. .020....
