I have a 1968 evinrude fisherman 6hp that I rebuilt from seized. I got this motor cheap and had to pull it apart and re hone/ score the cylinders. I used a ball one to do this and removed the rust from the bottom. I cleaned the Pistons and checked the rings. Replaced all the gaskets and checked all the points. I just ordered a rebuild kit for the carburetor. Had it running in the tank and idles good lags when giving throttle. Both cylinders read 70 psi. The issue is when I put it in gear it has low RPMs and goes slow. It pushes forward but only at full throttle. Fuel is 50:1 with sea foam in fuel. Using 89. Any suggestions or thoughts on how to have more power ?
