1968 45hp Wards character traits?
balex1873
Howdy all!! This is my first post here so I hope I'm in the right place.
I was given a 1968 Wards Sea King 45 hp mod# vwb27945B 86x outboard. This motor ran well about 5 years ago and has been stored since. My question is what if any bad traits should I check for (preventative mantainance). I hooked up a battery and turned this motor over which seemed fine, I also gave it a shot of starting fluid and it fired, so my next step is the test run in the drive way with water after I change the lower unit oil. What should I be looking for on this motor (rotten seals, wires, etc)? Any advice would be greatly appreciated. Thank you, Brian.
steven4141
Re: 1968 45hp Wards character traits?
Don't know much about the Wards, but starting fluid in a 2 stroke is the fastest way known to man, to destroy your engine. It remove the oil from the cylinder walls,( which it get from the oil gas mixture), this is a 2 strokes only lubrication. running it dry even for a couple seconds can lock it up. You might want to ask the guys in the other outboards section here on the forum about the Wards.
balex1873
Thank you for your reply, I will try posting around. "B"
