1968 100 HP Evinrude "No top end"
timcook
I recently aquired the motor and prior to running it serviced the lower end, changed the head gaskets, new points, plugs, rotors. <br /><br />Motor starts and idles like it was new but when you throttle up there is no power. <br /><br />The motor does not overrev. I have checked the prop and the electronic shift seems to lock up without slipping.<br /><br />Any ideas?
Goodoleboy
Re: 1968 100 HP Evinrude "No top end"
Welcome to the forum!<br /><br />Have you checked the timeing. If thats ok then I would guess you will need to clean carbs real good.<br /><br />Clean with engine tuner and blow out real good with compressed air. Also remove welch plugs.<br /><br />Also check real close for air leaks along your fuel line connections.<br /><br />Good luck.
