bass or bass ?
Thread starter- Joined
- Jan 31, 2009
- 68
O.K., here's the deal. I've had problems with this motor since I got the boat almost 3 years ago. It's an Evinrude Starflite 80 hp, 1967. It sounds fine running in a water tank, but under a load in gear, it can't get out of it's own way. I recently had the carb rebuilt, and there is a noticeable difference in starting and slow speed running. In gear, at throttle, the boat crawls along at slightly above no wake speed, and makes occasional sputtering sounds, and sounds and feels as though it's only runnung on 2 cylinders and wants to kick in and run on all 4. The plugs aren't new, but I've bead blasted them clean, and I'm getting spark on all 4 plugs. The ignition coil is not the proper Evinrude one, but an old blue Bosch Volkswagen coil. Could this be my problem, or plug wires, or the plugs thenselves, even though they are sparking when I ground them? At times this motor has taken off , slowly building up speed, and then running at 40 mph until I shut it off. Then it's back to the same old thing again. Deluge me with knowledge please. Thanks all.
