1967 Mercury 110 9.8hp Lower Unit
ThadBad
I have a 1967 mercury 110 9.8hp motor. I had the lower end replaced along with the water pump. Now when i put the motor in reverse it does not have very much power in reverse. Is there a simple fix for this problem???
dennyb123
Re: 1967 Mercury 110 9.8hp Lower Unit
You don't need to do anything with the screw that says "flush". It has nothing to do with the lower unit oil. All you need to do is remove the "middle screw" which is the vent. Then fill through the bottom screw hole until it flows out the vent hole. Replace both screws. Also it is wise to replace the gaskets for both screws. Very little oil is needed for the lower unit.
