1967 EVINRUDE 9.5 HP throttle problem
Chuck1947b
I am wondering how the throttle works on the above engine. On mine there is a throttle shaft that the buttterfly moves/pivots on. On the outside end of this shaft is a device that is about 3/4" long . I don't know what it is called but it spins freely on the shaft. Don't know if it should or not. Seems if it were welded/fastened to the throttle shaft that it would open/close the butterfly?? Other than that I can see no way how the throttle butterfly opens or closes. The carb was in good shape but froze up and I wonder if someone forced the throttle and broke this mechanism loose from the throttle shaft??? Also I have only the top half of the carb off and was wondering if it would be a good idea to go ahead and remove the lower half and clean the reed valves also or do those seldome mess up.
F_R
Honorary Supreme Mariner
There is supposed to be a tapered screw in the end of the butterfly shaft. Tightening the tapered screw into the shaft expands it and grips the lever thing you are speaking of. Having said that, it must be properly synchronized with the spark advance. I'll have to see if I can find a picture.
Chuck1947b
Thank you!! What a relief. I tightened the screw you were talking about and it worked. The butterfly moves. Great news brother. Now I need to do is to figure out the sync. All help is greatly appreciated,
Chuck1947b
Still need help trying to figure out how to set the lever on the end of throttle shaft. I have the flywheel off so I can see the pin that drives the lever but cannot figure out how to set the lever properly with the tapered screw fitting. Also I cannot shift into slow/stop with engine not running. Thanks guys.
Buickmike
Check out Leeroys ramblings.....i have rebuilt 2 of those little guys with his help...
