1967 500 thunderbolt 50 hp power issue
imand344
I have a 1967 50 hp on a 14 foot 1962 dorsett- I cannot get over 12 mph- its a 40-50 mph boat- it runs great in the driveway on the muffs, once on the lake - she doesnt do anything but troll- The pee holes are steaming. Is it an impeller? If so are they difficult to replace>? and where do I find out how to go about replacing it? Im mechanically competent- But is this a bad idea for a first timer????
RICKRICK1
Ensign
Re: 1967 500 thunderbolt 50 hp power issue
DONOT run that motor any more as it sounds like you may have fried it (over heated). First and most important get a good manual and read it about your motor. You need to do a compression check, all cylinders with in 10% of each other and pressure should be above 95 psi. If compression checks out. Next replace the impellar. Again please do not run the motor untill you have checked it out.
imand344
Thanks for the info Rick, I have ordered the whole impeller kit with the housing and all- <br />Ill let you know how the compression check turns out.
