1967 100 hp johnson is there diodes ? any1
michael4ever
Hi guys just wanted to know if there were diodes that controlled the voltage on a 1967 100 hp electric shift johnson
seahorse5
Re: 1967 100 hp johnson is there diodes ? any1
If I remember right, there was a diode assembly on the stb side of the aluminum flywheel guard on the '67. The '66 and '68 100hp motors each had completely different charging and ignition systems. Check the model number to be sure of your almost 40 year old motor.
