66Holiday924
Thread starter- Joined
- Aug 21, 2017
- 621
These are the little issues you get into not being able to do the work yourself and the right way.
The keyhole may be below the waterline in part but no way should it be getting wet from the outside, if so you have a serious issue with the transom assembly and are sinking. It does need to be sealed, raw wood is not a good thing in a boat. The guy cutting the hole should know that and should be just fine with your request to seal the wood and the holes he drills through. A small can of Helmsman Spar and a chip brush, it's sealed up. I don't think you'd be better served asking him to mix up fiberglass resin.
Pretty much my thoughts too, thanks for recommending the Helmsman Spar. I am a big fan of recommendations. I like tried and tested.
I don't think there will be an issue with the request. The only reason they wouldn't like it, is because it holds up space in their facility while it dries... They're going to have my boat for an entire winter though, plenty of time to work it in.
