classicfins
- Jun 15, 2001
- 12
Hi folks,<br /> I just found this site a little while ago and I love it. I have a problem with a Merc 1100. I bought it from a guy that had used it a couple of times and then pulled it off his boat to redo his boat. <br /><br /> Anyway, it had sat for about 6 months before I got it. I mounted it and tried to see if it would start, but it wouldn't fire at the plugs so I pulled the cap off and it was corroded. I sanded the contacts in the cap and it fired right up. I ran it for a day and it did ok other than the carbs needing rebuilt or cleaned.<br /><br /> A week later I went to start it just to make sure it would crank before taking my son to the lake for a couple of hours. It wouldn't fire at the plugs again. The contacts in the cap were not corroded this time and I don't know where to start to track down the trouble. Anyone have a sort of check list of where to start and what to check? <br /><br /> Also, how does the rotor come out? Is it pressed into the bearing of the points assembly or what? I can't get that sucker loose for nothing. I have seen a tool for removing the rotor on a mercury 6 cylinder, but I don't know if it will work on mine. The pliers have the part #32477 if anyone knows about these things.<br /><br /> I realize this messege is super long and I apologize. If anyone wants to email directly my email is classicfins@hotmail.com. Thanks!<br /><br /><br />------------------<br />Doug
