I swapped lower units out on my 66 60hp. I used a 59 lower unit on my 60 everything looks the same and bolts up. The lower unit works great the water pump pumps all kind of water and the lower unit goes in to gear great. Heres my problem. I am getting exhaust fumes into the engine cover and the motor will not stay running. I had no problems like this before. I have a manual and cannot find anything that i did wrong. Any ideas?
Thank you
Thank you
