1966 Evinrude Selectric shift coil issues
UncleJack
Hi everyone. This is my first post and I'm looking forward to hearing back from the knowledgeable community here. I've been browsing the site over the last few weeks and it really seems like it's "the" place to go. Very nifty!
I've got a 1966 Evinrude Lark viii 40hp engine in a little glass runabout that I'm getting ready for water. It's got the Selectric shift gearcase. The previous owner said it had trouble shifting into reverse and that the gearcase leaked oil. A bit of Web searching told me it was going to be trouble, but I love a good challenge so I dove into it. I got the engine going and it runs quite nicely but yes, no shifting to reverse. Fine then - I bought he correct factory service manual for it and took the lower unit apart. All the seals are bad and the proper coil power cable has been replaced wih just two wires and a mess of silicone. It wasn't hard to figure out where he water was getting in. Haha.
Well I'm already getting blabby so I'll get to the point. The mechanicals are in surprisingly good condition for having had water in there. The trouble is with the reverse coil - it's been rubbing the gear/spring carrier and is totally shot. This part seems to be pretty rare and expensive. I can find the forward coil no problem but that reverse coil not so much. From measurements I have taken it appears that the two coils are identical except that the reverse coil is pressed (or otherwise afixed) into an outer housing that has the four tapped holes into which the final bearing carrier or "gearcase head" bolts to.
My question is this: do I need to scour the earth for the rare proper part number reverse coil assembly or can I use a quite reaily available new forward coil and press it into the old reverse housing? OMC seems like a pretty savy manufacturer that wouldn't likely, in the interest of profit, make two distinctly different coils for this application. I'm going to make this happen one way or another even if I have to build my own coil, but I'm curious if anyone has any knowledge on this subject.
Thanks for listening, and thanks in advance for any and all responses good or bad.
jimmbo
Welcome aboard iboats
It looks like iboats sells both, there is only about a $20 difference.
OMC didn't make 2 different parts to make more money when selling replacements. If they could have used one part for both forward and reverse, they would have as it would have reduced manufacturing costs.
As for pulling the guts out of a front housing and trying to press it into a reverse housing, might be asking for trouble. Removing it might damage it, and same goes for installing it. It's only 20 bucks more new, you probably could find a used one on ebay for quite a bit less, but once shipping is factored in, the price between new and used might not be that great.
The shift system as it was engineered was sturdy and reliable. The correct oil is critical for proper operation, It was speced for Type C gear oil, OMC/BRP renamed their Type C, as Premium Blend. There are other brands of Type C oil, but not all are compatible with the Electric Shift gearcases.
UncleJack
Hi jimmbo, thanks for the quick reply! Thanks for the advise too. I'm a mechanic and machinist from way back but I'm new to boating. I did some searching for the coil but can't seem to find it. Can you point me in the right direction? Thanks again.
F_R
Honorary Supreme Mariner
Call iboats customer service and ask for part number 378665 reverse coil. Iboats has a source for OEM parts.
