Even new points often need cleaning and/or dressing. Especially nos ones.
Are the coils heels flush with the mounting boss? Should not be able to catch your nail running up the boss, but should not be too far back as to limit spark.
Did you test continuity through the coil to the spark plug boot? Ensure good connections along the way like at coil. You should get about 3000 to 8000 ohms resistance (this is secondary winding) from the spark plug boot, to the coil ground lead.
Run some wet/dry, or a points file, through the points many times. Blow off with compressed air. Dip paper stock, or a business card in acetone and run that through to clean. Then blow off with compressed air again. The littlest bit of dirt can limit spark.
I assume you have the points set to 020 when the widest part of the cam is aligned with the rubbing block of that points?
The spark plug spring punctured on center through the new plug wire? Cut back 1/4" of insulation on the wire there, fold the ends back, then insert the spring. Spray with wd40 then insert into the boot.
On the other end of the spark plug lead, the lead need to be pulled through the mag plate, TWISTED into the coil, so the strands wrap around the pin, then pull excess wire back through the plate, and tighten down coil. Don't forget to re attach clips that hold leads to bottom of plate, clean and re grease bottom of plate, before re installing. Not too much grease either, or it will get thrown off and foul the points.
After all said and done, the spark should easily jump a 1/4" gap on an inline tester with a bright blue ZAP!!
