1966 - 650 ​Carburetor numbers: replacement compatibility
Mercproject
I have a 1966 650, ser # 1869630 (Canadian) 4 cylinder.
The numbers on the top carb are KC54T (I can’t see the numbers on the bottom one)
(from the parts manual: Part # A-1335-2474, KC-5A)
I am considering the purchase of a spare set and have a couple of options.
One set is from a 1967 650 ser #2122557.
(Part #1335-3016 - KC5BT and KC5B).
and the other is from a 1967: Part # 1335-3016, KC5B
I am ASSUMING these replacement carbs will work on my motor.
Can anyone confirm or deny this assumption?
What do I have to look for in the way of replacements, exact number match only?
Thank you in advance.
Andy
Honorary Supreme Mariner
Nothing goes wrong with these carburetors that would warrant replacing them.---They are very simple and easy to repair / clean.-----Your location is ?
Mercproject
Thank you for the quick reply.
That is what I needed to hear.
I'll just clean them and give them a kit when the time comes.
Andy
in Saskatoon
These are an excellent smooth running motor.----Have one of those 66 models myself along with a few others from the 60's.--------Many parts are available here in Ontario.
