skinny1965
Thread starter- Joined
- Aug 3, 2010
- 148
ok so I had the head off to do a head gasket. the top piston seems to have a fair bit of pitting .I'm thinking it may be runing lean a bit.
the damage could have been done along time ago or since I have had it not sure first time with head off.
the manual I have said the high speed is factory set and no need to worry the low speed is on the peg that sticks out of the carb . I can turn it some more but that is just low speed
I do troll with this motor a bit so could it be working hard at low speed causing the ping
i mix at 40:1 should I change that
really don't want to blow it up
