1966 33hp choke shorted. What to do?
seedpws
Ok so last night I got all my wiring done with a new switch and found out my choke is shorted. If I move the power connecter on the choke it will work but only when you move it. Can you buy a new one cheap or what do you have to do to fix it?
tashasdaddy
Re: 1966 33hp choke shorted. What to do?
there nothing cheap about a boat. i searched for a replacement. came up with "0". take solenoid off and see if you can solder the connection. could not come up with parts number. but try tcoutboard.com
F_R
Hey, "boat parts" and "cheap" don't go together. However, the part number is 376806, changed to 385554, both listed as no longer available. Try Laings at http://www.laingsoutboards.com/
seedpws
I found two places that have it. One wanted $85 shipped and the other wanted $107. The http://www.laingsoutboards.com/ was the one for $85.
But for $85 for something that moves an arm when power is on it I think I am going to pull it off and see if I can fix it. Its just shorted out so I should be able to fix it.
tashasdaddy
i'd give it a try, if not you could just manually choke it. it's an option not a total necessity.
