1965 Johnson 9.5 HP Seahorse Prop Problem?
jarek36
The motor has been working fine all summer but I was out on the lake and about to head into the landing and when I put it into gear it idled fine but if I tried to go any faster the motor would rev to really high RPM and boat would go nowhere. I've been reading up and maybe it's a prop hub problem? Any suggestions would be much appreciated!
85 BOMBER
Re: 1965 Johnson 9.5 HP Seahorse Prop Problem?
Sounds like a spun hub in the prop. Most of the time you can have it rebuilt (if the prop fins aren't in too bad of shape) cheaper than buying a new prop. Have you checked the shear pin? I would check that first.
jarek36
checked the pin and that's fine. spun hup is what I'm suspecting. Thanks!
