1965 Johnson 5hp LD10s Missing Upper Seals On Drive Shaft
BWhaler17
Hello All
New guy on the forum I am looking for some help with a motor I am tuning up for my daughters boat.
1965 5hp Johnson LD10s.Motor ran for me in a barrel,but I want to minimize the headaches. I am in the process of replacing the water pump impeller and found some missing parts.The parts that appear to be gone are 1 thru 7 on the parts page. I am using the 1968 Ld-13b online diagram for reference. I have the correct part numbers and the parts are available, But why were they removed? Clymer manual only mentions an o'ring. This assembly or seals and spring appears to protect the upper splines from getting wet? is it common to remove them?
Thank you
Scott
Daviet
Re: 1965 Johnson 5hp LD10s Missing Upper Seals On Drive Shaft
The parts should be there to keep water out of the crank and block. Who knows why they were left out, but put them back in.
F_R
Honorary Supreme Mariner
Leaving them out leads to slow death of the powerhead internals from water ingestion. Also to slow death of the splines. Depends on which one comes first, stripped splines or tossed connecting rod. Either way, death is death.
BWhaler17
Thanks to both responses. I am going to order parts,want to do it once.I just tore apart a QD22 that I cannot get the shaft out of, I am assuming this would eventually happen if those seals are left out or fail.
Thanks again
Scott
Daviet
That could very well be the problem.
