Hello,
This is my first post here but I have already learned quite a bit from searching and reading, so thanks in advance!
I have a 1965 Evinrude 9.5 that will occassionally start, run for a minute or so, then cut off. Sometimes it wont start at all. The engine has compression of approx. 60 psi in each cylinder and does have spark on both cylinders. I have already replaced the points, condensers, ignitions wires and boots, and the spark plugs. I have also rebuilt the carburetor, and the fuel pump is reasonably new and does function. I bought this motor used and have no idea when the last time it actually ran was. Also, this afternoon it wouldn't even turn over with starter fluid. Is there something that I could have overlooked or something that I am missing here?
Thanks so much for the help
Glick
Glick
