scott_s211
- Aug 25, 2013
- 9
just bought this monster..got her runnin ..noticed no pee out of pee hole..shut her down..took a piece of wire..ran into pee hole and cleaned out..fired up..no pee still....dropped lower unit..checked impellar...stuck..ordered new one
upon inspecting lower unit i saw that down this open area at the front had mud or sand down inside and was packed in bottom about a inch or two..why?is there sand down there?also on out side of unit i saw a little pin hole ..i dumped water down where sand was and water came out of pin hole?why?is that hole suppose to be there..also i pulled my gear oil bottom plug out and water came out at first..then a mixture of oil and water ..then finally just oil?why?is there water in with the oil?after it was all drained out i poured water back in front area to see if that was breeched but none came out oil hole just pin hole..also i took the two pieces that go on the shift shaft off to grease them and think i put them back on the right way?question is ..is there a certin way they go?..they look like they only go in one way cause the top one is slotted?
i added some photos to see what im talking about...any info would be great and very apreciated..thanks scotty
