1964 Mirrocraft - Trim Tabs??
USMC1989
Hey Guys-
I've posted a few questions and appreciate the feedback received so far. So I've got another question for you! I've been doing some reading on trim tabs & think that they likely would improve my boats performance. My boat is a '64 Mirrocraft runabout that I'm turning into a fishing boat. I'm removing the full-width console & much of the front cover/deck & am going to install a floor with pedastals. The hull shape is similar to pretty much every other runabout from that era - low in the back, higher in the front. It is 14' long, aluminum, 16" transom, 62" wide. It has a 40hp Evinrude Big Twin, the original motor that came with the boat. The previous owner clocked it at 20mph WOT, verified on GPS. I thought that this was pretty slow for this motor on this boat (the boat is not a larger runabout with thick sides & flooring/seats, it's basically an aluminum shell with a couple wooden bench seats & a minimalist console (which will be going, to be replaced by a smaller side console). This motor, if running properly, should be PLENTY of power for this boat - it's the max HP that the boat is rated for. Looking at the boat with the motor attached, you can't help but think that it's going to be stern-heavy. I'm thinking that the boat wasn't planing/cutting through the water as efficiently as possible, and that self-adjusting trim tabs (either Bennett or Nauticus) might greatly aid in the performance. I'm confident that they would increase the initial acceleration/hole shot, but am wondering what effect they would have as far as top speed goes. The boat falls right in the middle of the two trim tab sizes offered in the self-adjusting style (one is for 10-14 ft boats, the other for 14-20 foot boats). I think that the smaller would be better - could still get the benefits/quicker hole shot, faster to plane, slower planing speed, etc, without having the larger tabs creating more drag than necessary. Any thoughts based on experience with these? Particularly regarding top speed?
Thanks in advance for your feedback.
Woodonglass
Re: 1964 Mirrocraft - Trim Tabs??
Marine, a couple of things. It's a lot easier and much more productive for you as an iBoat member to keep questions concerning your specific project all in one thread. Makes it a lot easier for everyone to keep track of everything. If you have specific questions on specific topics then asking them in separate posts is ok. This KINDA is that but I believe it's still basically related to your overall project.
2nd, I have a 1962 40 hp Evinrude Lark on my Fiberglass boat and when it's fully loaded with seats dual 6 gallon tanks and 600lbs of passengers, it GPS'd @ 25 mph. So 20 mph on a LIGHT aluminum boat indicates something is wrong. Wrong Prop, not developing Full RPM @ WOT, Not trimmed properly. But I'm sure it should push that boat upwards of 30 mph without trim tabs IF everything else is correct.
USMC1989
Thank You, Oh Wise One! That's actually what I thought too, regarding the speed. Do you see any need/benefit for the trim tabs, or would it be best to see how she runs with a properly tuned motor and new prop before adding anything else?
Oh yeah, and I'll try to keep my ramblings in one thread. Sorry about that.
Woodonglass
Personally, I don't see a need. Get her set up correctly and see what happens.
USMC1989
Thanks for the advice. I now see why you have reached the rank of Supreme Mariner.
