Re: 1964 Evinrude 75HP overheating help please
ok steve, what size are your head bolts, I think they need more torque than 15#'s I personaly run around the head 3 times checking then retorque after 1st warm up then again after about 10 hours of service, sounds like you are still getting combustion in cooling system maybe a hole in the exhaust chamber somewhere could have been that piece of metal you found. did you back flush the engine? have you pulled the lower unit to look at the water pump it may not be strong enough to circulate, I strongly recommend replacing it before you move on, also you need to get carb. kits and soak clean and blow out carbs w/compressed air, but study your manual first to see where exhaust can possibly mix with the water jacket and make sure there are no holes through anywhere,before you do anything, maybe someone that has had this happen to them will chime in and help us out.
