1964 Evinrude 5.5 Impeller Access
JDusza
Hi.
I have a 1964 Evinrude that needs a new impeller. I have the lower unit dropped about 3/4" and I believe it is hanging on the shift rod.
Can someone tell me how to release the shift rod?
And, ... before I forget, the shift lever is broken. It looks like it is mounted below the power head. Do I need to remove the power head to remove the shift lever?
Thanks,
J
Joe Reeves
Re: 1964 Evinrude 5.5 Impeller Access
Remove the powerhead, the linkage is underneath it. Not a difficult job.
JDusza
Thank you.
My big fear is breaking bolts.
J
JDusza
Got it!
Thank you.
Now, in taking this down, a couple parts jumped off the end of the drive shaft; spring, o-ring, cap. Can you point me to an exploded view so I can re-assemble correctly?
Thanks.
J
JDusza
I am all set, thank you, Joe.
I found the 1964 model on another site than I am used to using.
Cheers!
J
Joe Reeves
When encountering a frozen bolt/screw.... use a hand held propane torch to heat and expand the aluminum surrounding the bolt/screw to help loosen it. Have a fire extinguisher and/or a garden hose handy.
JDusza
Follow-up on impeller job.
When I dropped the lower unit, a bunch of items came off the drive shaft; looks like a seal backed with a coned washer, a couple of spring seals, a spring and an o-ring.
When I go to on-line parts lists, I do not see the exact same items I have.
My model is 5402 B and parts list I am referring to supports 5402. Any chance the B is a mid-year redesign cut-in that didn't make publication?
As part of this job, I need to get the power head-to-exhaust housing gasket and a couple drive shaft o-rings, so, I want to be sure I order the correct components.
Thanks again, Joe,
J
OptsyEagle
Here is a diagram of your motor. You want to order the powerhead gasket #313065 or sierra 18-2901 and you also want a new crankcase seal #303355 or sierra 18-2892. Both are very cheap and will ensure your motor lasts for another 50 years.
Joe Reeves
Very nice graphic there Eagle, very self explanatory.
JDusza
This is the unit. Thank you.
J
