1964 75 HP Hp Evenrude Speedifour: No Start
rdholmes
Model #: 75453 A
Serial#: E01697
Hello,
This motor generates spark, but it seems a little weak. It will not start. I changed the plugs and points. The small spring under the rotor is not factory. I was thinking it may need a new coil, but I'm not sure. I'm not that familiar with these motors. It has a magneto. Any suggestions??
Thanks,
Rich
freddyray21
Re: 1964 75 HP Hp Evenrude Speedifour: No Start
did you change the condensers? Weak spark can be caused by bad condensers.
rdholmes
not sure about the condensers. I had the work done by someone else. I'll have to check. Thanks.
Evinrude Boater
Was the motor running when you received it? Could be a lot of things
Chris1956
Honorary Supreme Mariner
Rich, the ignition system should generate a good "snap" when you spin the distributor pulley. The snap is the spark jumping to ground. If you do not get this, check the ignition coil for cracks in the plastic, dirty grounds and/or change the condenser.
You can eliminate the dissy cap, by running a test lead from the coil connector to grround, and see if you get a good spark when spinning the pulley.
