1964 -1967 2 barrel carb problem 60hp sportfour
shipwreck
1964 -1967 60hp 2 barrel carb problem, i just bought sport four evinrude engine. we start up the other day and fuel came leak out of the double barrel carbs from the top gasket which houses the float and needle and seat. which is where my problem is ..........i need to find a float replacement i looked and looked................................help can someone point in right direction. plus any tips you may have, got rebuild kit (gaskets needle and seat) but place dose not sell float for the model carb.
any know what brand or name this one goes by?
shipwreck
Re: 1964 -1967 2 barrel carb problem 60hp sportfour
pics
shipwreck
try again with pic
ezeke
I believe that the original Float and Float arm assembly number was 377164. It was also part of a carburetor kit.
ezeke
Too slow.
DHPMARINE
You might place the old float in liquid and see if it floats.If it doesn't you probably need #377164 float assembly.About $15.
What you probably bought was an aftermarket kit (like Sierra) which is fine,but often does not have ALL the parts needed.
An OMC/BRP carb kit has it all,and can be bought at your local dealer (as can just the float).
DHP
shipwreck
this is a rectangle float / not the round float i seen so much of dose the part still hold true?
shipwreck
how do get a Sierra master catalog or website address?
F_R
Honorary Supreme Mariner
The number we all gave you is the correct number for your rectangle float. It is the Evinrude/Johnson number for the original equipment part. The Sierra website is www.sierramarine.com They sell Sierra right here at iboats, but I don't think Sierra makes the float..
F_R
By the way, don't remove the venturis from your carb. They require a special tool to center them over the bores. It will run with them off-center, but might not be top efficiency.
tashasdaddy
laingsoutboards,com also has the parts you need. i found it best to call Jim, he will make sure your getting what you need.
