1963 Gale Sovereign
robstead
Hello everyone, while roaming through Craigslist I managed to come across this beast for $50.
I did the usual when buying unknown motors, but my only question right now is how is this spring supposed to be set up? I've tried doing research and kinda in a clueless rut as this is my first time working with a larger motor.
Any insight on this motor also would be very helpful.
F_R
Honorary Supreme Mariner
Hm.m.m.m, seems like I just answered that question somewhere else.
robstead
This is closely related to the Evinrude/Johnson of that era.
Yes, I've noticed that it is basically an exact replica of the Evinrude Fat Fifty and all the other HP versions.
After replacing a bunch of wires I ordered a timing belt and did the timing as I believe it should be. I lined up the timing mark on the flywheel and matched it to the one on the flywheel cover. I also lined up the distributor marks and put the belt on.
However when I went to go start the motor I noticed no spark. I took apart the distributor and cleaned the points in there and everything looks good. Tried again nothing. Reset the points in the magneto and set them to .020 as recommended and cleaned the points and reassembled, still nothing. Any suggestions on what else it could be? Also have the recommended spark plugs in, Champion J4C.
F_R
You have to identify where the actual problem is. Do you have spark at the coil button?
robstead
No Title
Most things you need will be in here.
http://www.fiberglassics.com/wiki/images/2/2a/Johnsonservice003.pdf Page 180 fig J81 will show how your throttle linkage goes together
Than you a ton for this, clears up a couple mysteries to me.
My next question that pops to my head after reading through that a couple couples is in the one picture is there a bracket missing? In the book it mentions a breaker plate, is that where it's supposed to be?
Also where the pink mark on the pulley lines up with the metal piece, is that the correct position to put the timing belt on or is the previous mark (second pink hash) the correct one?
robstead
What is the most effective way on doing this? Would any timing issues cause it to maybe ground out?
F_R
1. Remove the distributor cap. Coil is inside.
2. Hold a screwdriver across the top of the coil so that the screwdriver shank is touching the magneto housing and tip is 1/4" away from the button on the coil. Spin belt pulley, and sparks should jump across the 1/4" gap.
3. Timing has nothing whatsoever to do with having spark or not having spark.
4. In your previous post, "Breaker Plate" is the plate that the breaker points and condenser are attached to. I have no idea what those two holes are for.
5. You are nowhere near ready to worry about timing. Get spark first.
6. It is easier to work on that thing if you remove the whole assembly from the motor (3 bolts in black mounting bracket). Then you can access the distributor portion and coil. Clamp the black bracket in a vise---if you have a vise.
robstead
Did what you recommended and no spark on the coil. Could anything else be preventing this or is this a fool proof way to tell me that the coil is dead?
F_R
What this proves is that the trouble is ahead of that location (rules out the distributor portion). Next step is to zero in on the most likely cause. Remove breaker points and individually polish each contact shiny bright, then reinstall and adjust gap to .020" at widest opening. Also remove all wires from the stud that passes through the housing and polish all terminals and the screw and nuts and reassemble tightly. Don't lose the insulators. And never mind worrying about the kill wire that is also attached there.
After you have done all this, recheck spark at the coil.
robstead
Thanks for all the info, will do that and report back if there is spark.
robstead
Almost positive that I have done all this correctly and still no spark. What should be my next step?
Some of the bolts near near the coil that look like it would lead into the magneto a little rusted, is it possible there is moisture in there? Would heating the magneto up clear that up or is the problem most likely bigger then that?
F_R
If you have done all I told you to do, and no spark yet, it could be the coil. After all it is kind of old. Unfortunately, you need a coil tester to thoroughly test it. Meanwhile, how does it look? Any cracks, oozing, or anything?
robstead
It looks pretty solid, shiny black paint and the button looks almost brand new.
I can post a picture tomorrow of the condition if my eyes are fooling me and I might not know what I'm looking at.
Also going to test the condenser later and see the results, could this also lead to no spark at the coil if it's faulty?
robstead
No Title
Here's a picture of the coil, it looks pretty solid to me. Went ahead and tested the condenser and had no reading so I ordered a new one along with some points just to have an extra set handy, will post results when I install the new condenser
F_R
No Title
Coil looks like it has been replaced (not the original). They left the insulators out. Item 47, part number 510538. And where did they connect the ground wire?
robstead
I'm assuming this could be a huge loss to why there was no spark? Is there any alternative to ordered the insulators or is the OMC part necessary?
And the ground is hooked to the inside of the housing where the kill wire from pulley also comes down
F_R
The insulators are there to PREVENT something bad from happening. That bad something is arcing through the side of the coil to the case. If it is not arcing through, the bad thing has not happened, so is not the problem. But once it does arc through, the coil is shot. It's up to you to decide whether or not to put them in to prevent arcing through in the future.
Upon closer look, I guess I do see the ground wire, under the head of the screw that holds the coil in--where it is supposed to be.
