1963 Evinrude 40hp drive shaft lubrication question.
twostroke
Engine model number 40373D. Boating and Evinrudes are completely new to me. I am getting ready to assemble the lower gear case. The service manual I have indicates the use grease on the lowest bearing to hold the 20 loose roller bearings in place. There is no indication to grease any of the other needle bearings for the drive shaft. Are these bearings lubricated via the gear oil? The top needle bearing is above the filler hole, it needs to be greased? Thanks.
Chinewalker
No reason to grease the rest. The only reason to grease the lower one is to hold them in place for assembly. Once the motor is running, the grease liquifies and becomes part of the gear oil. DO put a dab of grease into the splines at the top of the driveshaft, though, between the o-ring and the top of the splined area.
jimmbo
Just don't put any grease on the top or end of the driveshaft
