Engine model number 40373D. Boating and Evinrudes are completely new to me. I am getting ready to assemble the lower gear case. The service manual I have indicates the use grease on the lowest bearing to hold the 20 loose roller bearings in place. There is no indication to grease any of the other needle bearings for the drive shaft. Are these bearings lubricated via the gear oil? The top needle bearing is above the filler hole, it needs to be greased? Thanks.
