nwcove
- May 16, 2011
- 6,293
Re: 1963 3 HP Johnson Seahorse----HELP !
+1 with lindy, the carb kit ($20 or less) has everything you need plus extra parts for different carbs. the thick gasket is crucial for even getting the motor to start! ( it wont suck fuel from the bowl without it sealing) . remove the welch plug ( drill a small hole in it...BE CARFULL to just drill through the plug, dont let the drill bit drop into the space below !)clean the carb...reclean it,run a strand of wire through every hole you can find. you probably will be very happy with the results!!
