StarTed
Thread starter- Joined
- Jul 14, 2015
- 694
Watermann,
You can't use muffs on a jet but I think I made up a way to connect a hose.
I'll take some pictures of the adapter that I made connected to the motor and try running it on a hose.
Basically I have a 3/8" plug on the side that goes into the water pump area. My adapter shoots water that way through a brass T allowing some pressure relief that is run around and shot into the intake. Hope that'll work allowing me to run it at home instead of running down to the lake.
The 2 lakes near me don't have docks so I backed the boat in and left it on the trailer.
Was going to use my little Kubota to move the boat around but it had a leak in a coolant hose. A trip to town and $1.99 got me a piece of hose that I had to form a 90 degree bend at one end. I kept it from collapsing by sliding a coil spring that was quite tight over the bend area. It seems to work just fine. I filled it back up with antifreeze and reassembled it before mowing some lawn.
Will try again tomorrow.
