1962 Johnson RX 10 C 1 cyl somtime miss
STOF
Hi,
I bought a 1962 Johnson RX 10 C and sometime 1 piston seems to have no fire and i cant put it on the idle. The compression is 110psi on both.
Anything has an idea ?
Also i would like to change the wire because they are damaged, anyone know how to remove the wire and the fly wheel and can i use car wire ?
Thank you !
