reavesga
Thread starter- Joined
- Feb 14, 2010
- 165
Trying to get the timing setup on a 1962 Johnson 40hp. I found the timing marks on the flywheel and the marks on the plate. How do I know which mark goes with the upper cylinder and which mark goes with the lower cylinder? Found one website that said there was a big mark and little mark but mine look identical. I set everything up and tried to start her. At low throttle all I got was a hard cough out of the exhaust. I advanced the mag plate as far as it could go without opening the throttle plate. The motor acted like it wanted to start but would not keep running for more than few seconds. Any suggestions? I am starting to wonder if I got the upper and lower plug wires swapped.
