1962 Evinrude Has Me Stumped!!!
nwcove
Re: 1962 Evinrude Has Me Stumped!!!
lol...dont let it get to ya!! as you are well aware.....those old omcs are as easy to work on as it gets.....sometimes they can be a stumper, but usually a good nights sleep and a new approach will give you a eureka moment. there are many members on this forum that only work on the vintage stuff....myself included. i would guess that your motor has some sentimental attachment???
OptsyEagle
I would take a close look at that boss gasket and of course the inlet needle when you take the carb apart again. Before you put the carb back on give it the personal blow test. Put your mouth to the carbs inlet with the carb right side up the air should blow freely. Now turn it upside down. Air should be fully restricted.
I would think that if you had a crankcase leak that was preventing fuel from being sucked in from the carb or being pushed into the combustion chamber that it would also prevent the fuel you sprayed into the throat from being suck in and/or pushed into the combustion chamber ...so I doubt a crankcase leak is your problem.
I think your problem is in the carb. Either the boss gasket, inlet needle or float stuck, air leak around carb to manifold gasket or your carburetor's venting is clogged up. Look for a big ugly bug in the air vent or whatever else. Good luck.
OptsyEagle
One last thought and I don't know the answer to this question, but what would happen if the welch plug wasn't obtaining a good seal?
OptsyEagle
One more last thought (this is the last). On my 1961 5.5Hp motor, when I engage the choke it also opens the throttle butterfly somewhat, to give it a minimum amount of gas for starting. You said that the choke is working properly. I assume you looked to see it closing the air butterfly in the front. Was the throttle mechanism of the choke operating as well. I assume a 10 HP works the same way.
StoneSails
Optsy- I will try that test on the carb. I guess it has to come off anyways. Welch plug is new. Lord knows Ive put in enough not to screw that up. Lord also knows that I could screw that up. I'll put in a new one when I take it off. But it still comes down to the fact that this motor ran after I cleaned the point and set them and when through the lower unit. I could not stop it from starting. A snap a wrist with that rope and she would go. Then that hot day as described above and the trouble started. Since then I have cleaned the carb 4 times. Soaked overnight twice and rebuilt on the last one.
StoneSails
Optsy-thanks for the input, I really appreciate it. Yes and Yes and Yes on your last post.
HighTrim
I don't think you will need to remove the welch plug again. I do however seal them as a habit now after I set them. 3m 847 or even your wifes clear nail polish will work fine. They don't all leak, but hard to diagnose if they do so I simply seal them all when I rebuild a carb to save a potential issue.
Optsy posted the steps I use as well to test every carb while it is off to ensure the needle/seat is functioning.
Ok I must have missed the part about it being able to run fine once it was "helped" by spraying pre mixed fuel into the carb. So it will continue to run fine after that and not die out after 30 secs or so?
StoneSails
HighTrim- No problem takin it out I have more welch plugs. I have enough 847 to last 3 lifetimes, so I will seal the new one. Runs like a dream after you get her goin. I ran it for 10-15 minutes last night. If you stop and restart right away-fires right off. Don't know what the cutoff time is yet to have to spray the carb. When its cold, You can pull till the end of days-she wont start. Spray it, choke it, and she goes. One more bit of info I forgot. Sprayed some mix down the plug holes and it ran on just that and quit. Going to try to see if that happens again just to prove it. No sense opening a whole new can of worms. Unless that tells you guys something I havent thought of. Havent got back to it yet today.
HighTrim
Huh, so the carb needs a prime to get her going does she.
Try richening both needles 1/2 to 1/4 turn out CCW when cold starting. Does that help?
OptsyEagle
Ran good too. It literally would take a 1/4 or 1/2 pull, cold, and it would run. Then one day it was about 95 degrees out. My tank had some air in it. I connected it and the bulb felt weird. It felt full of air instead of fuel. Pumped it anyway and disconnected it and let the air out of the cap of the tank and the line. This is when I started having these problems.
Hmmm. I am just thinking out loud here. So it appeared that the tank and line was filling with air. Even if the tank wasn't vented (was it at this time?) any expanding air should have pushed gas through the line until the inlet needle closed. I can't imagine 95 degree heat would create more pressure then a person squeezing the primer when the carb is full, and I do that just about every start up. Do you remember if there was very much gas in the tank or should I say a lot of trapped and expanding air? Are you using a new inlet needle then what was on the carb at that time? Are you using a new carb bowl gasket. I believe the fuel on that carb goes through the bowl gasket to get up to the inlet needle. Really dumb question. Is the bowl gasket on correctly and not covering up a hole? Sorry, have to ask.
Give it a blow test once you take it off as well as before you put it back on again, just to make sure.
OptsyEagle
Actually none of what I said in my last post will matter since I think you said that the motor runs great once it gets started. So obviously gas is getting through to the bowl so there really cannot be any problems with the inlet needle or bowl gasket covering any inlet hole.
It has to be in the things that make it start. The choke and the slow speed circuit, including the needle and the welch plug. I am not sure if it matters, but did you set the throttle cam to the carb roller, correctly, making sure the choke was not engaged when this was set?
Be sure to take HighTrim's suggestion and turn out the needles a little and see if that helps. Add more throttle gas as well. Go past the start mark if you haven't already tried that. Not sure if that will matter but give it a try.
One more question. When you spray gas in the carb throat and you get it running for a while. Is it still hard to start when it is warmed up?
StoneSails
Just got in. I have been thinking a lot about this problem. I think I remember pumping up the bulb and spraying the carb got her going then feeling the bulb wasnt that hard. So I thought I dont have very much gas in the tank. Mixed up another gallon of 24 to 1 and put it in. Pumped up the ball, choked it, and half way through the pull she pops off and goes. So now I don't know what to think. I already know Im a Idiot, but this is what happened in the beginning. It would run great then it didnt. Maybe all the little things added up to one big problem? If that was it I apologize for wasting everyones time, but somehow I feel, like a beautiful, cold hearted woman, shes gonna turn on me again.
BTW- Optsy-95 degrees outside, tank was in the garage. I don't know closer to 100F in there? Gonna let her sit try cold tomorrow and see what happens. If no start, I will try the carb test and replace the welch plug.
Gonna feel dumber than I look if she starts right up again tomorrow.
Woodstock60
Im remembering having this problem on a 9.5 hp. if it has the same carb ( long and narrow like a straight six) . The carb had two or three small holes plugged up, about the size of a bb. They appeared to be plugged with lead or some similar metal and one of the plugs fell out. check that, I had several of these carbs and finally got one to work.
Tom Maslar
You said you have a tank known to be good and you are stumped...hmmmmm....try another tank
StoneSails
quagmire- different carb. This is more the style you would find on a newer 9.9,15, 25. Just a little smaller and has the manual high speed adjustment. Does have lead shot though. Tapped them for a good seal on the first of four carb cleanings.
Tom- When I was having all this trouble, I switched tanks, several times and it did not make a difference. Yes the tank was full, vented, hose hooked up right direction, and a tank I use almost every day-so i know its good.
Thats why I was surprised when she started last night first pull out of the blue. It has done this before. I dont know. will see if it starts today.
tmasloske
When the motor is cold, try pulling out and holding the choke out with your left hand and pulling the motor over with your right hand at the same time. I have a 1960 Evinrude 10 and for some reason I have to do this when it's cold. When I do this it starts on one or two pulls. After warming up, no choke and starts on one pull. If I don't do this when it's cold, I can pull forever and it won't kick over. I think if the choke butterfly has even a slight gap and isn't closed tightly, there's not enough vacuum to suck the fuel.
By the way, my Evinrude 10 is the smoothest idling motor I own. Just like a sewing machine.
StoneSails
tma- I have noticed that about the choke. It will be open ever so slightly. I straightened the rod on the top that pulls the gas forward to start. That seemed to help. Still need to pull the choke smartly though. As far as my problem I addressed the choke a long time ago. And I do visually check to make sure its closed all the way. Still had problems after that though.
handifly
If you need to do a tear down, a complete gasket set and complete lower seal kit available from vintageoutboard. They also have a carb float, not included with most carb kits
Carb kits are still available from OMC, about $10 more than Sierra. I got one from my Evinrude dealer when I was in a rush.
HighTrim
They are more, but the reason is the float is included. You will end up paying more buying a Sierra carb kit, then buying the float separately later.
geoffwga1
We seem to have tried just about everything here and it has not worked.I have had the same problem with several motors and in every case.despite me being convinced otherwise cos i had "seen to it".It's obviously not a fuel delivery problem as it runs OK once you get it going so there's nothing wrong with the tank or the line or the bulb or the fuel pump,which brings us back to the carb and I would almost be prepared to bet real money the problem is in your low speed needle packing.That MUST be good of you want to start the motor.Once it's running it's almost redundant so it's not so important.Time and again I have dismissed this and have had to go back and eat crow when it turned out to be just that.I hope your problem is as small in the end.Put 4 washers in if you have to but make sure no leaks. Good luck
Geoff69a1
