StoneSails
Thread starter- Joined
- Aug 25, 2011
- 19
First time poster. Long time info miner. I have a 1962 Evinrude 10hp. Model 10024. She only starts when mixed gas is shot in the carbs. New: coils, points, condensers and plugs. Points cleaned(New & Cleaned) set at .20. Compression at 80 & 80. Great blue spark (a little more than a quarter inch). Carb has been cleaned 4 times. Soaked overnight twice with welch plug out. Rebuilt the last time. Float set good (level-once, a little high opposite the hinge end-now) drop between 1 1/8 and 1 1/4. Sprayed and blew out, of course. One time with the carb off, pulled manifold and reeds. Nothing broke, chipped, bent. Good spring to the reeds too, then some nos gaskets. New fuel lines and switched fuel pump with known good fuel pump.
When gas mix is sprayed in the carb she starts and runs like a dream. She runs out fast ( in a tank) and runs down so slow you can read the flywheel.
I work on outboards for a hobby, and have a known good hose and tank. If you dont spray the carb you can pull till hell wont have it and it will not start. I have worked on outboards on and off for 20+ years and I'm stumped. Heeeeelllllllpppppp!!!!! Please.
Gotta be the carb? Right?? Not atomizing the mix? Crankcase not sucking? Can a carb actually go bad? Because that would be a first for me. I wish I had a spare. Need new needles? Any help would be greatly appreciated.
StoneSails
StoneSails
