archbuilder
- Sep 12, 2009
- 5,697
Re: 1962 Arkansas Traveler restoration
One more thought, since you have the cap off, why not just cut some foam pieces out and hot glue them to the transom....put some plastic on the front side, then just lay up your glass on the foam. Once you have a couple layers on, just slide the plastic and foam out....then pour the seacast in the void? All you would really need is some foam that is the right thickness. Once you get the cap back on, you can tab it to the transom.
