micks110
Master Chief Petty Officer
- Sep 14, 2009
- 879
Re: 1962 Arkansas Traveler restoration
Thanks Arch! Yeh- It definitely is a good feeling. But the problem with this point in the project is there is not one or two big projects, it's a thousand little ones that require back and forth to the store a hundred times!
Triton- you beat me to my posting- you peaked at photobucket! I got done at 2 am last night so there was no way I was posting then- it had to wait till today.
Last night I got done with the second coat of white on the bow- that was good enough so I pulled the tape- exterior paint is DONE!
The old sandpaper tape paper stuff
[/IMG]
A little bit of and upgrade I think
[/IMG]
I also installed the steering cable for the second and hopefully final time.
I ran the wiring to the switch behind the steering wheel for the bilge pump.
I installed the unicharger the same place it was before.
Before
[/IMG]
After
[/IMG]
I also ran the wires for the throttle cable as well. I will be spraying the box and arms with the charcoal metallic to freshen it up again.
[/IMG]
[/IMG]
Of course all the stuff I put in last night will need to be disassembled and taken out when I paint but I want to make sure everything is in it's place before I paint.
I think tonight I'm going to install the fire extinguisher and call it quits- I'm beat today!!!
I saw andgots speckled paint job and it has me thinking of doing the same on the walls on the inside of the boat because it is the rough textured fiberglass on there and it probably won't look to great with bright white paint on it. I'm thinking the white base paint, and then the ocean blue and charcoal metallic speckles. We'll see when I get there.
Before
After
