1962 18hp seahorse
Snowman1994
Hey guys I'm stumped on my motor. Everything's been redone on it and I have fresh gas but it's a pain to start. It takes upwards of 50 pulls to get it to even think about starting. Once I do get it started she runs great except it doesn't like to idle at real low rpms. I've messed with the low idle control on the top and I understand that it should be turned out 1.5 turns, started and then slowly turned back in while lowering the throttle until a sweet spot is found but I'm having trouble getting that spot. I'm not sure if this has anything to do with it not wanting to start but I do know that I have to have the throttle up pretty much maxed in the neutral position and the choke on for it to go and then I have to be quick and throw it in gear and give it more for it to stay running. Anything u guys have to offer will help. 62 Johnson seahorse with reverse no electric start if that helps at all.
F_R
Define "Everything" has been done. Does that include the ignition system, especially the coils? No 18hp Johnson requires 50 pulls to start. If it isn't running after 5 pulls at the most, there is something wrong with it. Stop pulling and start troubleshooting.
Yes, correct starting position is to put it in neutral, then advance throttle as far as it will go (it will only go to the start position when in neutral). And yes, pull the choke if a cold startup.
Agreed define " everything " here.----------When you pull the choke knob is the flapper fully closed ?--------Is it still closed after a couple of pulls ?----------Choke detent comes to my mind.
im actually replacing a broken detent on my 1964 evinrude 18hp. Is there a trick to getting the rod and detent installed together? do you slide the detent over the rod and press it in? or do you install the detent then shove the rod in. It doesnt seem to fit either way for me...
TN-25
If the motor has been idle a long time, dressing the points is an often overlooked step. Just saying... Check plug gap as well because incorrect gap will let a motor run at speed but be a bear to start.
Thanks Racerone! i had some trouble getting it in and didnt wanna force it too hard so that it didnt break... But a good push and it slide right in!
