Snowman1994
Thread starter- Joined
- Oct 12, 2016
- 1
Hey guys I'm stumped on my motor. Everything's been redone on it and I have fresh gas but it's a pain to start. It takes upwards of 50 pulls to get it to even think about starting. Once I do get it started she runs great except it doesn't like to idle at real low rpms. I've messed with the low idle control on the top and I understand that it should be turned out 1.5 turns, started and then slowly turned back in while lowering the throttle until a sweet spot is found but I'm having trouble getting that spot. I'm not sure if this has anything to do with it not wanting to start but I do know that I have to have the throttle up pretty much maxed in the neutral position and the choke on for it to go and then I have to be quick and throw it in gear and give it more for it to stay running. Anything u guys have to offer will help. 62 Johnson seahorse with reverse no electric start if that helps at all.
